Setback Thermostats
Ken Ditchfield
Member Posts: 10
Has anyone found reliable information on the most efficient way to use a setback thermostat? Even the manufacturers give very little information on the ratio between on and off cycles, the number of degrees setback that is most efficient, and how all of this might be related to outside temperature.
Thanks!
Thanks!
It varies by location
and house, system size, insulation, and weather.
Without any info to compare, no info would be even close to accurate about how much fuel would be usedl or saved.
I'd compare it to predicting how much fuel would be used to travel across the country.
....without knowing how far it is, what fuel it is, who is driving, and if you were using a car, plane, bus, or train.
Your mileage may vary.
Noel0 -
Might I suggest...
that you send your question to (bill.wolfe@honeywell.com)
Bill should be able to get the info that Honeywell has for using their thermostats.
Glenn Harrison, Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Services
Crystal Lake, Illinois
Althoff Industries website0 -
setback stats
Honeywell's new electronic setback stats all feature +- 1 degree accuracy. They come in a variety of price and feature ranges, from the basic T8112D to the top of the line T8600 and PC8900. If you can tell me a bit more about what kind of system you have, I'll get back to you with specifics.0 -
stats
Thanks, Glenn.0 -
Any time Bill. (nm)
) 0
- 167 Indoor-Air Quality
