Funky air valve
Jeff W
Member Posts: 12
This is probably old hat for you guys, but I found this valve pretty interesting. Have we seen a lot of these out there?
Here's a little bigger view--it says Richardson on one side and June, 1913 on the other.0 -
That's their main vent
the check allowed vacuum to form. There's an adjustment screw on the other side for the thermostatic element. Nice find!Retired and loving it.0 -
Where
did you find that? Did you take it off an old 3-in-1 Vapor/Vacuum/Pressure system? That's what it was designed for........
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 167 Indoor-Air Quality
