Street Ell
DanHolohan
Member, Moderator, Administrator Posts: 16,544
how the name came to be?
Retired and loving it.
I was told
that it was a filling used to tap into the top of a water main in the street to connect a water service into a home. The tap was made at the top of the pipe to keep debris out of the water service and they wanted as few threaded connections as possable underground.Bob "hot rod" Rohr
was it ?
,,,,,,,,,,,,,,because plumbers cannot spell avenue,,,,,,, or could it be the person that named it lived on a one way street & it can only go one way????//0 -
Street El Correct
Hey Dan!!
TGO is correct.
John0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
