Radiant Heating Coil out of Material? In a tank of water?
Mark Barber
Member Posts: 1
Hello:
I would like to make a coil out of radiant tubing, in a tank of water. How do calculate the heat transfer rate of different types of material.
1. Stainless Steel
2. Copper
3. Pex Tubing
4. Black Sch 40 Steel
1. Stainless Steel
2. Copper
3. Pex Tubing
I have a couple
and I wouldn't mind having one for PEX as well. PEX isn't as good of a conductor as metal though. Air isn't either. Water is about 10 times more conductive.
Hope this helps a little.
:-) Kca:-) Ken0
- 167 Indoor-Air Quality
