1\" crimp tool
jay_3
Member Posts: 22
i need to make two crimp connections on 1" pex.but i can't
afford to spend $300+ on a crimp tool for only two connections. does anyone rent them? any suggestions?
thanks,
jay k.
thanks,
jay k.
What brand tubing?
And where are you located?
Usually the supply house where you bought the tubing will have the tools for rent.
Mark H
mark, i'm in new jersey(southern part). the brand of tubing
is watts e-pex.
jay k.0 -
what about cts compression fittings with ss insert sleeve? nm
is watts e-pex.
i'm the supplier of watts and we normally do rent the crimp tools. however we don't have a 1" available for rental.nor
does anyone else in are area for that matter.which is surprising. i guess there just isn't a lot of 1" pex being
used around here.my customer didn't want to purchase the tool upfront. he figured he would be able to "find" one
somewhere.(rent/borrow). i'm trying to help him out however
possible.
thanks, jay k.0 -
i suggested that but he wanted to stay w/ the factory fitting and crimp rings since it's going to be buried.0 -
Crimp tool
Geeze, if you weren't so far away I'd let you borrow mine.
Try going to the Watts-Radiant site and do a distributor search. Just enter your zip and the closest one should pop up.
Copy and paste the following link.
http://www.wattsradiant.com/replocator.html
Hope this helps!
Mark H
- 167 Indoor-Air Quality
