Frozen underground plastic water pipe.
I love you man...
unless your reaaaaaaly quick :-)
Just another set back to not using copper :-)
(where's ken when you need him)
I use to hook up a welder to the curb stop and the main inside line, can;t do that with plastic :-)
How do I thaw a plastic underground water pipe?
Here in Northern Minnesota, we have had sub zero weather with no snow this year. Many people are experiencing problems with frozen water and septic pipes.
I need to thaw a 1" black plastic water line that is burried 6 feet below ground and is 30' long. I know some use steamers, but I can't find a source for them. Any suggestions would be apprecieated.0 -
if its a block wall it might be air droping down the core bust a hole in the block and try a hair dryer . let us know if it works
The freeze is 15 feet away from the building foundation, under 6 feet of earth. I used an electricians fish tape to probe down the line to measure how far away from the building the freeze starts.0 -
Frozen
We've had great luck thawing these types of lines out by pumping hot water into them.We made up a rig that uses a propane burner,a transfer pump, and 1/4" copper tube.
frozen pipe
Might try a hot water flush, fish down the pipe with a smaller sized 3/4 plastic pipe. You can get the pipe at an Irrigation supply house.0 -
Why Not
Purchase a roll of the smallest pex tubing you can, hook it up to the hot water heater with a backflow preventer and a small pump. Then fish it down the line. Turn on the pump when you get to the blockage.
This should eat right thru a frozen line.
I would suggest turning off the main unless your reeeeaaaaly quick .
Scott
frozzen pipe
You can rent a jet water snake at most rental places.
It will fit down the black pipe you have.
Just hook it up to hot water.
The standard jet snake pushes a jet at about 1000psi.
That will work for sure.
I've done this my self more than once.
Good luck.......0 -
Maybe I can use a plastic welder...
I know, I know.... I didn't use copper
Maybe I'll find someone with a plastic welder and try that.... ;-)0 -
Buy a Arctic Blaster
Its so simple it will blow your mind , and it will only take a half a gallon of water and 15 minutes to thaw that line.0 -
Thawing plastic water pipe
1st Need lead pot burner
2nd 6" well casing pipe,capped top and bottom,20"+-high
cut top 3/4"nipple in top,3/4"tee,15 lb releif on top,bush bull of tee for snifter valve with core removed.
3rd 3/8" hose to snifter,1/2" hose sewer.
4th Fill 1/3 water,set on burner,fire up,10 minutes steam,hose down pipe,will go by itself (little help)when in ice.Runs about 15 minutes.
Weld top & bottom & nipple.
Will go over 75 ft.Never really measured.0 -
Artic Blaster
What is it in detail0 -
Arctic Blaster
Just ordered one! Thanks for the advice!
For $500, including shipping, this seems like a great unit. Simple design, no moving parts, and includes 2 50' coils of braided tubing... 1/4" & 3/8".
Also, it doesn't require a connection to a water supply... which is a plus when it is the main line you are trying to thaw.
Check it out at http://www.arcticblaster.com0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
