Byproducts of Propane Combustion. (hb)
heatboy
Member Posts: 1,468
Can anyone share with me what the byproducts of propane combustion are? Specifically, what does the condensate have in it. Propane makes quite a bit more condensate than natural gas, if I remember correctly, at the same exhaust temperature, but I dont know what it is composed of. I am producing 5 gallons of condensate per day with my 11-44. Anyone help?
hb
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hb
If you are condensing -
all of the water vapour - then for each cf of propane - 4 cf of water vapour would be produced. As for all the other goodies that are supplied with commerical propane - butane, methane, propylenes - it depends on your supplier. The mercaptans are in for the ride too - but we are told that they are completely consumed by the combustion process - hope this helps.0
- 167 Indoor-Air Quality
