No PEX within 12\" of recessed lighting?
Paul E.
Member Posts: 7
Why is it that they say not to install PEX within 12" of recessed lighting? Is it because the lighting might heat/melt the PEX? Or is it a UV thing (light escaping from the can might hurt the PEX?)
On a planned underfloor staple up job, in the basement I have IC rated recessed cans for lighting. Above the cans would be a layer of insulation, then the aluminum plates, then the PEX. I can touch my hand on top of the recessed can without pain <g> - it doesn't seem like the light can is gonna hurt tubing with 130 degree water running through it???
Thanks,
Paul
Thanks,
Paul
Who
says this?Retired and loving it.0 -
I believe it is in the Wirsbo design manual...I have read it as well.
I don't know, but I assume it is fear of heat and a tube actually touching a can and eventually melting.
That's my guess and assumption.
If its burried behind insulation...I can't believe its a problem at all. I have it over my cans anyways.0 -
sounds familiar
I recall hearing the same thing. I believe I heard it at Wirsbo factory training. It may have more to do with the high temp affecting the lighting. I'm not sure but I will check my notes and get back to you if I find anything.
I believe
It's because of the heat potential. All pex, that we've used, has the same standard as well it's a part of our local code.
:-) Kca:-) Ken0 -
safety first?
would it have something to do wiuth putting waterline over electrical device?
same reason you do not run your waterlines over your breaker box.
Terry
Here's the links to RTI's manual -
For the plumbing pex, top of page 6 they say 12" vertical and 6" horizontal clearance with a little drawing:
http://www.radiant-tech.com/assets/documents/PlumbingDesignInstall.pdf
For the heat pex, just one line at the bottom of page 6. No explanation why in either case.
http://www.radiant-tech.com/assets/documents/HeatingDesignInstall.pdf
-- Paul0 -
The newer style
can lights are a double wall product with thermal cut out switches. I have noticed these IC's run much cooler than the old style cans.
If you "over bulb" them they trip the thermal cut outs. Hard to believe you coulcdn't pex within a foot of those, especially with insulation between!
hot rodBob "hot rod" Rohr
bonded
What do you think about bonded pex-pipe with an aluminium coated surface inside. No fear of heat.
Ciao Rene0 -
The aluminum
would do fine, it's the PEX that still has an issue with the heat..
:-) Kca:-) Ken0
- 167 Indoor-Air Quality
