What is this fitting?
Steamhead
Member Posts: 16,883
it works the same as the Honeywell Unique valve that Mark posted. Can't wait to see a pic of this one!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
FHW fitting
I have a FHW system (I think it used to be gravity) with cast iron rads. Two of the rads on the 2nd floor have a fitting I am trying to identify-any help is appreciated. The feed and return both come up through the floor about 6 inches apart. The feed has a valve on it. Both the feed and return tie in together then go into the same radiator tapping. The return line goes into a tee that must be some kind of diverter, right? Anyone know what I'm talking about? How do these things work?0 -
Sounds like
a single entry valve. Does it look like this? If so, I think Stadler sells them.
does it look like this?
Well, Mark
We've given him two options and he isn't responding. Do you think he's waiting for some more choices?
Do you mind if I copy your sketch for my files?
Best wishes,
Alan
better ask Dan
since I "borrowed" it from the gravity heating section of the Q&A here at heatinghelp.com. Pretty sure it's out of
his "how come?" book.
More diagrams over in the Q&A about the internals of the valve, too.
Mark0 -
Hey there-
Sorry, I didn't disappear, I just don't check computer often.
Nice pictures, but not quite what I have. The radiator shut-off valve is a regular one, with the union tailpiece made into what looks like a bulky tee fitting. The other side of the run of the tee has a nipple, then goes into the radiator. The branch of this "bulky" tee is the return line down throught the floor. Does that help?0 -
Can you
post a picture of it?
I will take one tonight and post it tomorrow....Thanks.0 -
Here's the pic...
Does the T have a bushing in the side where the supply is?
It may be a double tapped bushing. I don't have picture posting capability so you'll have to visualize. If the side of the tee where the supply comes in has a bushing, it may be double-tapped and has a nipple inside that goes to the other end of the radiator. The water returns across the radiator and exits into the tee around the smaller nipple and out through the bottom outlet on the tee. This may have been done because both ends of the radiator were not accesible or (if these radiators were added later)so that the two pipes could be run up close to each other.0 -
Perhaps?
cheese0 -
by cheese
I think he's got it ...
That looks like what he's talking about. Now, tell me what it does ??
Scott
Be the water ..........
the appearence seems to "baffle" the mind:)........but what if the tee (or the tee is)is actualy two 90* ells,but to the unsuspecting eye appears to be an impossible fitting for flow.
Getting "warm" Mr.Scott?:)
cheese0 -
two 90 ?
So the tee has baffle, and it blends the flow ?
What was the purpose ? Ease of installation ?
Sssssscccccoooottttttt.
waiting for spring.
I believe
there's an internal pipe that extends from the valve, though the tee, and into the center of the radiator. The return flows from the radiator through the bull of the tee.Retired and loving it.0 -
Wow, you guys are good. Here's the pic anyway.0 -
Thanks
for the picture, Joey. We all learned from that one.
Cheese was sharp enough to have a photo ready for us to look at and Dan gave us an explanation of how it works.
You've got to love this place.
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
