unfamiliar tubing
EricR_2
EricR_2 Member Posts: 43
I'm in Colorado Springs, We have an area of town that used Bundy tubing for interior domestic water and baseboard heat lines.
  • Tim Carlson
    Tim Carlson Member Posts: 12
    radiant tubing
    Ran across a radiant tubing that I can't identify? The house was built in 1949. The 1/2" tubing was suspened below floor and painted black. After sanding off the paint expecting copper I found a stainless metalic shine, the product used is not black steel, but it is magnetic,bendable and it does have welded/brazed joints. What might this product be?
    Thanks Mark!
  • EricR_2
    Bundy tubing I think
    Anyway thats what we call it, I think it was used during WWII and after. I have been successful in soldering it but it is very touchy to excessive torch heat. If possable use compression couplings to do repairs.
    EricR
  • Sounds like
    Bundyweld which was made during the war years and is some type of copper/steel composite.
    A lot of it was used here in the Bay Area for radiant, but I think most if it has failed by now since it didn't hold up well becuase of the ferrous component.
  • There you go
    Both Eric and I posted at the same time....with the same answer.
    I always used to think Bundyweld was a west coast phenomenon or a name the old timers came up with, but I guess it's a true product name.
    By the way, Eric: what part of the country are you from?
  • Sven
    Sven Member Posts: 34
    Bundyweld ..
    still looks like it is made:
    http://www.lapham-hickey.com/Products/SteelTubing.cfm
    Check out this tidbit:
    "William, double-flaring hard lines is mandantory IF you use std steel brake
    line, which is also known as "Bundyweld". Bundyweld is rolled sheet steel that
    is furnace- brazed together to make a tube; single-flaring will almost always
    split it at the braze line, causing a leak. Double flared bundyweld does not
    split. This by the way is '30s technology that was never updated. Conversely,
    it is almost impossible to double-flare stainless steel tube because of the
    instant work-hardening it does. So for SS, I think single flare is OK- we used
    single flares on ss tubing in Lockheed's spacecraft w/no problems. And
    remember, bundyweld is the only "official" DOT-certified hard line except for
    Pat Mical's Future Auto ss hard lines. Don't know which flare Pat uses. J"
