Flushing single pipe steam system
I have a 1940's era single pipe steam system that in in pretty good shape. I had to change a pipe on the return side of the Hartford loop and the pipe was clogged with sludge. I assume that a lot of the system is in this condition. What is the best way for me to flush the system clean? Do I open the Hartford loop at the union, remove all the radiators, make a fresh water connection at each one and flush the system out top to bottom?
I did notice that the smell of "stagnant water" shows up in the house if the system fires up after being down for a couple of days.
Thanks in advance.
-Jim
