unfamiliar tubing
EricR_2
Member Posts: 43
I'm in Colorado Springs, We have an area of town that used Bundy tubing for interior domestic water and baseboard heat lines.
radiant tubing
Ran across a radiant tubing that I can't identify? The house was built in 1949. The 1/2" tubing was suspened below floor and painted black. After sanding off the paint expecting copper I found a stainless metalic shine, the product used is not black steel, but it is magnetic,bendable and it does have welded/brazed joints. What might this product be?
Thanks Mark!
Bundy tubing I think
Anyway thats what we call it, I think it was used during WWII and after. I have been successful in soldering it but it is very touchy to excessive torch heat. If possable use compression couplings to do repairs.
EricR0 -
Sounds like
Bundyweld which was made during the war years and is some type of copper/steel composite.
A lot of it was used here in the Bay Area for radiant, but I think most if it has failed by now since it didn't hold up well becuase of the ferrous component.
There you go
Both Eric and I posted at the same time....with the same answer.
I always used to think Bundyweld was a west coast phenomenon or a name the old timers came up with, but I guess it's a true product name.
By the way, Eric: what part of the country are you from?
Bundyweld ..
still looks like it is made:
http://www.lapham-hickey.com/Products/SteelTubing.cfm
Check out this tidbit:
"William, double-flaring hard lines is mandantory IF you use std steel brake
line, which is also known as "Bundyweld". Bundyweld is rolled sheet steel that
is furnace- brazed together to make a tube; single-flaring will almost always
split it at the braze line, causing a leak. Double flared bundyweld does not
split. This by the way is '30s technology that was never updated. Conversely,
it is almost impossible to double-flare stainless steel tube because of the
instant work-hardening it does. So for SS, I think single flare is OK- we used
single flares on ss tubing in Lockheed's spacecraft w/no problems. And
remember, bundyweld is the only "official" DOT-certified hard line except for
Pat Mical's Future Auto ss hard lines. Don't know which flare Pat uses. J"0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 985 Plumbing
- 389 Solar
