Honeywell Control
It is a Honeywell Model STG94L-EIG-00000-MB
0 to 125 PSI
ST 3000
S-900
It is located on the high pressure side of a gas regulator on the gas service to a Cumberland Farms I was out consulting on today. The wires run up to the roof top unit (boy was it cold up there today). The local gas company does not know what it is. I could not get hold of Cumberland Farms personnel. I called fire dept and they do not know. Anyone know what it is? What does it do?
0 to 125 PSI
ST 3000
S-900
It's a gauge pressure transmitter.Found the info on honeywells site.0 -
Thanks Rich
I will look it up. I just can't figure why it is on Cumberland Farms unless they are monitering pressure at some remote location as it is wired up.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
