check this out
ScottMP
Member Posts: 5,882
That particle board is tough to drill thru ....
LOL
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
LOL
Scott
Not my employee
What not to do!0 -
Is that for real? Or did you doctor that immage? lol Tops a former employee of mine who fixed a leaking B&G circulator with lots of white silicine at the weep hole in the bearing assembly.0 -
Thats a HX !
to pre-heat the water to the shower valve via the shower drain waterGreat idea, so simple.
hot rodBob "hot rod" Rohr
forgot to seal off the holes the pipe goes in with silacone
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
