low water cut off
John@Reliable
Member Posts: 379
Does the boiler shut down due to leak of water,or do you just fill it? Also do you check level after unit has been off for aleast 15 min. , this will let water in piping return to boiler, also is it every 2 or 4 weeks? Steam(air)vents on raditors and mains leaking alittle steam? Over time this can cause also. Hope this helps
John@Reliable
John@Reliable
LOW WATER CUT OFF PROBLEMS
help...I have a 2 pipe steam system a two year old weil mc clain boiler sgo6. No auto water feed. how long should the water in the system last before I have to add more? I know stupid question my old boiler never need water added.This boiler can't be trusted 2-4 weeks before i have to add more water. I have checked and replaced 3 vavles on radiators. Should i need a water feeder? how much water can be lost from the air valves on the returns? any other suggestions?0 -
Returns
You shouldn't have to add water that frequently, Approx once a month, it should have that in your owners manual. Do you have any underground returns that could be leaking? Is the near boiler piping done properly so your getting dry steam up to your system. Definatley look through your owners manual and look at the near boiler piping diagram, it all starts at the boiler, However, if you have buried return lines it is not unusual for the new boiler to stir up some problems. Now, you say you have 2 two pipe system with VENTS on the radiators? Do you have steam traps on the radiators as well? I have only seen this once before, however there were no traps. The water has to be going somewhere, it should be coming back to the boiler.
Good luck, Ant
Another thought
There's a lot less water in the new boiler than there was in the old boiler.Retired and loving it.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
