rpz certificate
paul_14
Member Posts: 16
does anyone have any info on where in ny you can attend classes to get certified to do rpz inspections?
RPZ
Paul, I have been searching for this info myself. The only one I came up with was David & Warshow in Maspeth. I was trying to find one closer to Westchester County.Chris0 -
what is R P Z0 -
RPZ
Illinois you must be a licensed plumber first, then State Dept. of Public Health gives a five day course and test,its called a CCCDI license. Backflow protection should be on all boilers0 -
it is
It stands for reduced pressure zone. It is found on a backflow preventer0 -
rpz
in ny, i know of davis and warshaw and also at the local 1 union hall they give the classes ,but you must have your mechanics book first!im gonna give davis and warshaw a call -thanks0 -
backflow on boilers
Agreed, but what about open systems? Does a water heater become a boiler if used for hydronics? Is this a gray area or black & white?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
water heater boiler
If the water heater is used as boiler, yes. Open system as in open to atmosphere most definately, open as tied in with potable water, that is illegal in our state and in most I believe,although it goes on all the time.0 -
location?
Bill,
I agree. What state are you in & is that in a code format you can copy or obtain for my use(G).
Thanks,
Dave Yates - NEWWA certified - we test & install a ton of BFPers.
Thanks for the link, Bill.
There is a bunch of info there that I can use.
Glenn Harrison Residential Service Tech
Althoff Industries Inc. Mechanical and Electrical Contractors
Crystal Lake, Illinois0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
