rpz certificate
paul_14
paul_14 Member Posts: 16
does anyone have any info on where in ny you can attend classes to get certified to do rpz inspections?
  • masterplumb
    masterplumb Member Posts: 93
    RPZ
    Paul, I have been searching for this info myself. The only one I came up with was David & Warshow in Maspeth. I was trying to find one closer to Westchester County.Chris
  • jim f
    jim f Member Posts: 182
    what is R P Z
  • Bill Barrett
    Bill Barrett Member Posts: 43
    RPZ
    Illinois you must be a licensed plumber first, then State Dept. of Public Health gives a five day course and test,its called a CCCDI license. Backflow protection should be on all boilers
  • zeb_3
    zeb_3 Member Posts: 104
    it is
    It stands for reduced pressure zone. It is found on a backflow preventer
  • paul_14
    rpz
    in ny, i know of davis and warshaw and also at the local 1 union hall they give the classes ,but you must have your mechanics book first!im gonna give davis and warshaw a call -thanks
    hot_rod Member Posts: 25,443
    backflow on boilers
    Agreed, but what about open systems? Does a water heater become a boiler if used for hydronics? Is this a gray area or black & white?
  • Bill Barrett
    water heater boiler
    If the water heater is used as boiler, yes. Open system as in open to atmosphere most definately, open as tied in with potable water, that is illegal in our state and in most I believe,although it goes on all the time.
    location?
    Bill,
    I agree. What state are you in & is that in a code format you can copy or obtain for my use(G).
    Thanks,
    Dave Yates - NEWWA certified - we test & install a ton of BFPers.
  • Glenn Harrison
    Glenn Harrison Member Posts: 405
    Thanks for the link, Bill.
    There is a bunch of info there that I can use.
    Glenn Harrison Residential Service Tech
    Althoff Industries Inc. Mechanical and Electrical Contractors
    Crystal Lake, Illinois
