panel rad connectors
kevin
Member Posts: 420
I'm installing panel rads in my house. :) I am doing the manifold set up as opposed to the diverter tees or R&R... The connecetions Buderus has only allow you to go w/ 5/8" pex conections (that I can see). Is there another way or a part # that I am missing that will allow me to go from the rad connection directly to 1/2" or 3/8" wirsbo? tia kpc
Buderus fittings
For 1/2" pex p/n 1016874
For 1/2" copper p/n 6198924
For (12mm) pex p/n 1016870
For 5/8" pex p/n 1646851
They also have them for Kitec size tube (17mm)
Call 1-800-283-3787 if you have questions. The guys at Buderus will be happy to help you out.0 -
thanks!
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
