Steam Actuators with end switch ?
Fellas:
I have a steam Actuator (5 wire) that I am told needs an end switch in order to start the Oil Burner as the Valve opens. I'm not sure how to wire this, as I have never done it. There is RWB to motor and TT for Transformer.
Can anybody draw me a schematic on how to add and wire in this end switch? There are 3 others (3wire) which bring on the burner as the valves open. Confused. Somebody added this 5 wire & it doesn't work.
John
