Naked Chicks!!!!
Paul Pollets
Member Posts: 3,656
"The Perfect Boiler" in The Roundtable below...or
http://forums.invision.net/Thread.cfm?CFApp=2&Thread_ID=3162&mc=13
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Naked Chicks!!!!!
I can't believe there are no responses to the question on "The Best Cast Iron Boiler". What is up with that?0 -
The Best Boiler
is the one that is selected and installed by the best Contractor.
Boy is that a tough one.
What you need to find out is, what is the best boiler for the customers needs, type of heating system and space available for installation.
That is just the tip of the ice berg in boiler selection. The n you need to come back to the building 20 years later and find out if it is still there and what if any repairs were made on the boiler.
Then compare that to all the other boiler you selected and you might learn that you installed a quality boiler.
Best is subjective and not necessarily fair, because I had a friend that installed the best boilers, his measure was how many free vacation trips he got from the manufacturer during a promotion.
Jake0 -
The Best Boiler
That is just the tip of the iceberg. You will need to come back to the building 20 years later and find out if the boiler is still there and what, if any, repairs were made on the boiler.
Then compare that to all the other boiler you selected and installed. At that point might learn that you installed a quality boiler.
Best is subjective and not necessarily fair. I had a friend that installed the best boilers. His measure of what is best, was, how many free vacation trips he got from the manufacturer during a boiler sales promotion.
Jake0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
