Running exposed pipe..
Bob W._2
Bob W._2 Member Posts: 79
Whats the best way to conceal pipe if you have to run it exposed (vertically) next to masonry walls? This would be new pipe for a HWH system, with separate runs to new panel radiators. Could you run the supply and return next to each other and cover both with a pipe wrap?
  • Bob Cat_2
    Bob Cat_2 Member Posts: 14
    fiberglass insulation
    I would not try to insulate both pipes at the same time; it never looks good. Why are you trying to conceal them? for safety or looks? They also sell a hard pvc wrap to cover the fiberglass.
    Bob Cat
  • Dale
    Dale Member Posts: 1,317
    A wood decorative cover?
    If it were open a bit at top and bottom no heat would build up if you didn't want to insulate the pipes.
    hot_rod Member Posts: 25,441
    Colorful PVC jacketed insulation
    is available from www.techlite.com. Numerous colors and wall thicknesses available. Makes for a nice looking insulation in exposed places.
    hot rod
  • Bob W._2
    Thanks..
    I was thinking about routing out channels for each pipe in a 2 piece wood cover. Could stain it and it would look like an old steam pipe.
