Running exposed pipe..
Bob W._2
Member Posts: 79
Whats the best way to conceal pipe if you have to run it exposed (vertically) next to masonry walls? This would be new pipe for a HWH system, with separate runs to new panel radiators. Could you run the supply and return next to each other and cover both with a pipe wrap?
fiberglass insulation
I would not try to insulate both pipes at the same time; it never looks good. Why are you trying to conceal them? for safety or looks? They also sell a hard pvc wrap to cover the fiberglass.
Bob Cat0 -
A wood decorative cover?
If it were open a bit at top and bottom no heat would build up if you didn't want to insulate the pipes.0 -
Colorful PVC jacketed insulation
is available from www.techlite.com. Numerous colors and wall thicknesses available. Makes for a nice looking insulation in exposed places.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Bob "hot rod" Rohr
Living the hydronic dream0 -
Thanks..
I was thinking about routing out channels for each pipe in a 2 piece wood cover. Could stain it and it would look like an old steam pipe.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
