Panel Radiators
Aidan (UK)
Aidan (UK) Member Posts: 290
Most houses here have Myson, Stelrad or Barlo (www.barlo.co.uk) radiators.
Runtal and Hudevad (www.hudevad.co.uk) are usually found in high quality commercial projects. I don’t know that you’d be able to get all of these makes.
  • Brian_5
    Brian_5 Member Posts: 5
    Panel Radiators
    I have been installing panel radiators from Myson and Runtal for a awhile now. I am looking for some research or just an experienced opinion on what other people are installing out there when a customer is looking for that European style radiator.
    Has anyone had experience with other brands like VEHA and can anyone offer any suggestions for good towel warmer radiators?
    Any suggestions or experiences would be appreciated!
    Who do we think is the best brand panel radiator out there?
    Brian
  • ScottMP
    ScottMP Member Posts: 5,882
  • Michael B
    Michael B Member Posts: 179
    we sell a lot of the runtal uf series
    baseboard. Clean, out of the box and the new tops make the install really clean. If you are looking for something really crazy check out a company called Bisque. They are much more expensive and are not generally stocked (in other words special order) but if you have a client looking for something really unusual this is the ticket.
    www.bisque.co.uk
    Michael Bleier
    Able Distributors
    "The Supplier Who Works With You"
    www.abledistributors.com
  • Steve Ebels
    Steve Ebels Member Posts: 904
    Get in touch with
    Hydronic Alternatives and ask about Radson or if you want some wilder stuff, Vasco has a lot of neat looking rads with all kinds of accessories. Karen Orlando can point you in the direction of someone in you area that caries them.
    The radson line is very nice quality and these folks also carry Oventrop valves and fittings.
    www.hydronicalternatives.com
    Or 413-543-8733
  • Dave     (Canada)
    Dave (Canada) Member Posts: 11
    I recently installed 6 panel rads made by Stelrad
    They are a resonable price, made in the UK
    Web site is WWW. Stelrad.com
    Canadian distributor, phone # 705-286-4398
    Dave
  • Theealchemist
    Theealchemist Member Posts: 55
    Re: Veha Rads
    We just recently installed a combination of rads. We used Myson Coloums and Veha Towel Warmers. The Veha's are Priced great for a towel warmer. Our Clients also liked the rotated tube Design.
    Our only complaint is the Mounting detail for the Veha's. We ended up using a colored Chair bottom to hold the Rad's Bracket off the wall enough to meet our angle vale Depth. (see Pic's)
  • Theealchemist
    Re: Veha Rads
    We just recently installed a combination of rads. We used Myson Column and Veha Towel Warmers. The Veha's are priced great for a towel warmer. Our Clients also liked the rotated tube Design.
    The Wall mounting detail for the Veha's was a bit Different. We ended up using a colored Chair bottom to hold the Rad's Bracket off the wall enough to meet our angle valve Depth. (See Attachments)
    Steve@
    Alchemyinc.com
