How long will they last?
Vince
Member Posts: 8
Hi,
Will anyone give me a guess on how long galvanized pipes will last?. Mine are over 70 yrs. old. I have a hot water system. Thanks, Vince
Twice as
long as half the time it takes them to leak. You have asked a question that is extreamly difficult to answer. The first thing is the condition of the water. Then there is the pipe its self. Like does it have a red stripe painted sprial around it? That would be a special corrosion proof pipe. Next could it be extra heavy pipe ? 70 years ago the pipe was better than it is now. even the standard grade. If it is burried anywhere it may be attacked by the outside corrosion factors. I have seen gal pipe compromised by earth in as a little as two years. And pipe inside hanging in basements that is still going at 150 years.
bigugh
Oxygen
I learned (here) that there is not much free oxygen in a closed hydronic system. Corrosion is therefore very slow.
That (and I would suppose velocity, to some extent) is why iron fresh water pipes are so short lived.
My black iron pipes are 80+ years old, and show no signs of failure. Recently pulled out a section for reconfig, and was amazed to find that the insides were still in excellent condition.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
