Sizing Gravity conversion circulators.....Boilerpro
I'd checked all that
and everything looked OK. They hadn't had a problem with the old boiler, which is what made me look at the circ.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
FLOWMETERS
We specify circuit setters (B&G, Taco) on all commercial and larger jobs. They can be adjusted over a large flow range, but require a differential pressure meter to read the flow. Dwyer and others make rising ball flow meters in different ranges, which are cheaper.0
