Baseboard to PEX in the same loop?
anthony_7
Member Posts: 72
Well another beutiful day on L.I.
I am wondering if I run a loop using pex and connect to BB then on the return line use pex then to cover my bathroom floor on same loop back to boiler with no bb in bathroom and enusre a comfortable bathroom. CONFUSING Any pros, cons??
Basically I want to use the pex Supply to connect to BB and on the return cover my bathroom with the return line and tile over it and keep it going back to boiler.
Thanks all
Thanks all
Sure
In Dan's book, Pumping Away, on page 98 there is a picture of something very similar to what you are looking for. It should work pretty well.
Andy Morgan
R.Morgan Mechanical, LLC0 -
Dont have that around
Do you have the cliff notes handy?0 -
concerns
wouldn't you be concerned on overheating the floor running approx 160-170* water under tile??
Try this
http://www.pmengineer.com/pme/cda/articleinformation/features/bnp__features__item/0,2732,62497,00.html
I noticed the beautiful diagrams did not come up, but I hope this is temporary.0
- 167 Indoor-Air Quality
