5/16 th pex and embassy manifolds
kev
Member Posts: 100
I am doing a job with 5/16th wirsbo pex and would like to use Embassy manifolds, but the fittings are not compatible.Does anybody know an easy solution other than using 3/8ths couplings to transion with? Why are all pex fittings not standard? (that may be a dumb question)
I know this is a silly question.................
but why not just use Wirsbo's manifold assemblies?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
I may
but i have had good luck with the embassy manifolds and the control they provide on both supply and returns.0 -
Or you could use Rauhau's
Tubing is same spec as Wirsbo... don't know if they have 5/16 though.
Boilerpro0 -
Rehau...
doesn't make 5/16" tubing 3/8" is the smallest.
kf0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
