Convert Miller furnace from L.P. to oil ?
chris smith_2
Member Posts: 37
oh one other thing i like to use the ,579mh nozzles /orange cap/ they are made just for a miller and work well
chris smith
porter maine
chris smith
porter maine
Sorry to ask this again but, is it possible to stick a oil gun on a Miller trailer furnace. It now has a gas pwoer burner on it. I want to put it in my shop where there now is a old drip pot burner. Thanks0 -
miller
find your local miller rep and make sure that you can do this on the model furnace you have, if you can you will have to change the combustion chamber, find a burner that will fit behind the door,if going into your shop check your vent/chinmey or perhaps power vent it, unless you have a suitible gun[new $300+], powerventer [new $300+],combustion chamber[ new $40] and enough experiance at this type of work [don't know if your in the trade] you might find for an extra $300 or so you can have a brand new heater instead of an older trailer furnace
chris smith
paradise porter maine0 -
Thanks
Yes I'm in the trade. And the power burner looks like it bolts on just like a oil burner. I have a used oil gun. The furnace in question was owned by a very good freind of mine and is only a few years old. I will check with miller.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
