What is a Refractometer?
Hey Guys I'm serious!
Anybody know what a Refractometer is and what it does exactly? What does it look like, and where would you buy such a thing?
John
  • Bill_14
    Bill_14 Member Posts: 345
    Definition & Source
    Check here: http://www.misco.com/sitemap.html
  • Alan R. Mercurio
    Alan R. Mercurio Member Posts: 588
    Refractometer shows battery, antifreeze levels
    For example Kernco Instruments Co Inc's makes the Model 1016 battery/antifreeze tester is a hand-held refractometer designed to indicate specific gravity, freezing point temperature, and battery charging levels.The test takes only a few seconds. To do it, place a drop or two of the sample on the prism surface, hold it up to a light, and read propylene glycol (-60° to 32°F), ethylene glycol (-84° to 32°F), or battery fluid (1.100 to 1.400 specific gravity), depending upon sample selected. The battery fluid scale also shows condition, such as “recharge,” “fair,” and “good.” This tester has a blue filter system that gives sharp, clear readings.The Model 1016 weighs 7 ounces and is 6" long. It comes with an adjustable knob for easy calibration and has a rubber eyepiece guard that shields out extraneous light. For additional information, contact Kernco, 420 Kenazo Ave, El Paso TX 79928-7339.
    Your friend in the industry,
    Alan R. Mercurio
    Oil Tech Talk
  • Mason
    Mason Member Posts: 102
    refractometer
    A refractometer is a device used to measure percent composition of viscous fluids. What would it mean to one of us... It would be used to determine the amount of "anti-freeze" in a system(or for those of us who work on both sides, it could be used to test refrigeration oils). This instrument is an optical device that I would not let ride around in my truck any more than necessary. They usually sell for between $200 and $500. and are usually "job" specific
  • Robert_3
    Robert_3 Member Posts: 1
    Refractometer
    I use a refractometer in my job as a machinist. Ours resembles a telescope, we use it to measure the level of concentrate to water ratio in the coolant. A small amount of coolant is applied to the far end & then you look through the eye viewer & the % level is shown.
  • John G. Merritt
    John G. Merritt Member Posts: 140
    Now I know-Refractometers
    Thanks Bill,Allan,Mason for your input on Refractometers.
    Now I know whjat it is,what it does and where to buy one!
    Nobody I know (other techs) knew anything about it.
    I need one to test Radiant systems.
    Thanks again,
    John
  • John G. Merritt
    Refractometers
    And thank you Bob!
    John
  • hr
    hr Member Posts: 6,106
    Testing the waters
    Here are the testers I keep on my truck. The Misco is available online for around $149. www.misco.com. The ph and hardness are from Graingers also available online. These will give you a good start on testing water, and glycol solutions. More involved testing I send out to a lab or glycol manufacture.
    This sample sent to Dow shows more info.
    hot rod
  • Refractometers
    Basically a refractometer is a prism that splits light. You place a drop of the liquid that you want to test on the glass plate, close the cover, look into it like you would a telescope; and you will see a line on a graduated scale. This number will give you the specific gravity of the substance you are checking. Refractometers are used to tell you how much glycol is in the system; and being a former employee of Pepsi, it will tell you if there is enough syrup mixed with your carbonated water; you can tell if Arbys is gyping you when you buy a soft drink; or if they are making money hand over fist. Hope it helps, Joe.
