WATER HEATER
paul_14
Member Posts: 16
I HAVE A 40 GALLON PGXL AO SMITH WATER HEATER THATS ABOUT 3 YEARS OLD . IM NOT GETTING A LOT OF HOT WATER . THE WATER IS HOT BUT ITS RUNS OUT TOO QUICKLY..WHAT SHOULD I CHECK FIRST THE DIP TUBE . THE UNITROL...?
yes
the dip tube sounds like the problem
Our \"old-time\" plumbing house
stopped selling A.O. Smith a few years ago for this reason and WAY too many premature tank leaks. They had sold them nearly exclusively for decades (I believe). Owner showed me a room stuffed and stacked with units recently replaced under warranty. I was returning a 2-year old leaking heater at the time.0 -
Have you considered tankless
Paul. You will NEVER run out of hot water again.
Try www.endlessslyhot.com and tell Darrell Thomas Brian said hello.
Regards
Brian.0 -
water heater
is there a different dip tube for the low boy?0
- 85.7K THE MAIN WALL
- 50 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
