Tankless Water Heaters ie: www.astravan.com
Marian D-J
Member Posts: 2
Re: Gas "Tankless Water Heaters" Example www.astravan.com
"Bosch" Can & Would you Recommend? It's usage for our new home? We have 1400 sq ft. of 4 zone in 3" slab concrete and we have 1400 sq ft. zone in plywood using the "McDuff " System. We would like to add it for a 17' wading pool. We have 3 showers and 2 laundry rooms.
Sincerely,
Marian D-J
Sincerely,
Marian D-J
Tankless Water Heaters?
Sincerely,
Marian D-J0 -
96 LS/AWD
My '96 LS/AWD model has been pretty reliable. It did overheat once when the thermostat stuck. Don't think it would be suitable for domestic water heating.
Wait, mine's an astrOvan. Never mind.
Mark0 -
Bosch Heater
These heaters are illegal to be used for hot water heating purposes in Manitoba. For domestic water needs, keep in mind the units on average will only supply enough hot water for one shower at a time.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 983 Plumbing
- 389 Solar
