Definition- Power vs. Hand 'tools'
Mark Walnicki
Member Posts: 21
So could a power tool be defined as a tool that fits any of those categories, but is powered by anything other than a human?
Definition- 'Hand' tools
Having a discussion with another individual. What is considered a construction "hand" tool? Is it the hammer and screwdriver, is it the jigsaw and sawzall, is it a non-electric carpet stretcher or a lathe chisel? Any thoughts appreciated. Thanks- Greg0 -
A hand tool is any device that can be used for the purpose of fixing or modifying the hand, such as fingernail clippers.0 -
Definitions
Hand Tool: A tool of any mode of power intended to be carried by the user while in operation. Examples: screwdriver, circular saw, chisel, hammer, pneumatic drill, etc.
Bench Tool: A tool of any mode of power intended to be placed on or attached to a bench when in operation. Miter saw, miter box, vice, dovetail jig, mini-versions of larger tools, etc.
Stationary Tool: A large powered tool that must be immobile when in operation, either by gravity or mechanical connection. Table saw, jointer, shaper, planer, etc.0 -
Thanks...
The whole situation revolves around 'business personal property' regarding property taxes. Some exclusions apply, but the local county appraiser's office has to struggle with whether or not certain tool items fall under statutory exclusions or fit within another label.
Greg0 -
Tools
In the trades the tools that you would carry in your tool belt to perform the work of your trade are considered hand tools. As a union carpenter I am required to supply my own hand tools, but our by.laws restrict us from using our own power tools ie: any tool with a cord or a battery. The contractors we work for are required to supply all power tools and or specialty tools not normally associated with carpentry work. I think this is common amongst most trades.
Whether this is the definition of a taxing authority I do not know!
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
