CO2
Dave Palmer
Member Posts: 186
a good co2 detector for testing homes we work in,any ideas?Thanks Dave Palmer
Do you
Mean CO as in carbon monoxide or CO2 as in carbon dioxide?0 -
Dave Palmer, CO or CO2 detector
TSI Inc. 1-800-777-8356 or Bacharach 1-800-736-4666
These are quality products and somewhat expensive but very good and you can be assured that they are field accurate.0 -
thank's Murph
CO or CO2 testers
Dave, before you invest in any tester, what are you trying to accomplish with this tester? A CO2 tester is used for ventilation testing, CO testers are used for safety of equipment. CO2 testers test houses, CO testers should be used to test equipment and sources of CO.0 -
want
to test house,co2 levels in houses0 -
CO2
Bacharach has a unit called a Canary that is a good CO2 tester.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
