Day 2 completed peerless ect 6 with 80 gallon aqua booster
Joe Grosso
Member Posts: 307
Very small boiler room.A little hard to take good pictures but here they are.Job went alot quicker than we thought,Fired it up around 1 pm.
LWCO position?
Looks a bit high, water level too.... supposed to be that way?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Looks like he piped it that way
To keep the water level higher in combination with the feeder . Im not positive , but I think I heard you shouldnt do that with a 67 LWCO . Better off using the probe LWCO in the higher of the 3/4 holes in the front of the ECT . I like the Unimatch feeder - comes with a big delay and orifices to slow down the fill speed .0 -
Nice work Joe
I get the feeling they wont run out of hot water with the coil and aquabooster . And you took the extra time to connect the returns and equalizer in black . We've been installing a ball valve and drain on the returns to flush em out - especially on those crappy wet returns thatll bring back the spooge with the ECT running full tilt . Did you find a good spot to skim the boiler ? And is that humongous backflow preventer required on all steam boilers ? Im kinda ashamed to show what we are required to install - looks like a gnat compared to that one .0 -
steamhead
I have done this alot when we install dual lwco.We really do not have any problem with over filling the boiler. The plumbling inspector has told me this is ok when I install dual lwco.Also had smith give me the ok with this.I do not do this when just install a 67.Sorry the pictures are not better it was a very tight boiler room to take pictures or work.0 -
Backflow
Any boiler over 300,000 btu in nyc requires the large backflow preventer.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
