BACK BOILER PROBLEM
I have a 'back boiler' within my chimney breast.
I had to turn the water mains off the other day (which I have done before with no problems) as soon as I reconnected the water after doing no work the cold water is flowing fine but the hot water is fine for a few seconds but then dribbles.
Please help as I do not know what to do
  • ScottMP
    ScottMP Member Posts: 5,882
    Damien
    I don't know what to do either, I've never heard of a Back boiler ( back breaking boiler yes ) or a chimney breast.
    How about some more info ?
    Scott
  • Noel Kelly
    Noel Kelly Member Posts: 43
    I remember those.
    I would venture a guess that you are from the other side of the Atlantic Damien.I have yet to come across a back boiler over here. I would also venture a guess that yours is a plumbing problem - you have an obstruction in the hot side in which the pressure builds when faucet (tap) is closed. Will run fine when first opened but slows due to restriction. Call a plumber!
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,651
    He's from
    the UK.
    Retired and loving it.
  • Gary Usa_2
    Gary Usa_2 Member Posts: 45
    back boilers
    hiya i am from the uk and living here in the usa,i was a corgi ,oftec registered plumber their,what type of back boiler was it a baxi 551 the ones with the spreaders into the return on the heating side,is it still on gravity on the heating side and onto a cylinder,or is it fully pumped
    please let me know what type and the system set up is and i can help you all i can
    all the best
    gary usa
