BACK BOILER PROBLEM
Damien Tubridy
Member Posts: 1
I have a 'back boiler' within my chimney breast.
I had to turn the water mains off the other day (which I have done before with no problems) as soon as I reconnected the water after doing no work the cold water is flowing fine but the hot water is fine for a few seconds but then dribbles.
Please help as I do not know what to do
Damien
I don't know what to do either, I've never heard of a Back boiler ( back breaking boiler yes ) or a chimney breast.
How about some more info ?
Scott
I remember those.
I would venture a guess that you are from the other side of the Atlantic Damien.I have yet to come across a back boiler over here. I would also venture a guess that yours is a plumbing problem - you have an obstruction in the hot side in which the pressure builds when faucet (tap) is closed. Will run fine when first opened but slows due to restriction. Call a plumber!0 -
He's from
the UK.Retired and loving it.0 -
back boilers
hiya i am from the uk and living here in the usa,i was a corgi ,oftec registered plumber their,what type of back boiler was it a baxi 551 the ones with the spreaders into the return on the heating side,is it still on gravity on the heating side and onto a cylinder,or is it fully pumped
please let me know what type and the system set up is and i can help you all i can
all the best
gary usa0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 996 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
