out door oil tanks
ed wallace
Member Posts: 1,612
I have a customer who lives in a mobile home has been heating with kerosene he says when he was heating with oil the oil would gel up in the winter my question is in Nova Scotia Canada ive seen a lot of outdoor oil tanks what do they heat with oil or kerosne ? any body in Canada on this web sight thanks in advance
outdoor oul tanks
I have a customer who lives in a mobile home has been heating with kerosene he says when he was heating with oil the oil would gel up in the winter my question is in Nova Scotia Canada ive seen a lot of outdoor oil tanks what do they heat with oil or kerosne ? any body in Canada on this web sight thanks in advance0 -
In our neck of the woods, fingerlakes region in ny state, 42 N Latitude, folks often put "winter mix" in their outdoor tanks. I think maybe 20% kerosene or something along that line.
We once had repeatedly cold nights, about -35F, for a week or so. One morning the oil had jelled enough apparently in the line that the scorched air burner wasn't happy and shut off. I got out the heat gun and warmed up the filter. This was in a very old, poorly insulated farm house with a very cold basement as well...especially when it is -35...night after night. Cold valley. Never have had any pipes freeze, although sometimes I wonder why not...suspect movement and proximity to the floor above.0 -
One trick set up that I seen ..........They built a shed around the tank and ran a set of 100watt light bulbs in side. They were enough to keep the oil from jelling.....
P.S. -35 , dang that's cold......0 -
outdoor oil tank
There are various types of fuel additives which lower pour point by 25 degrees F.( At minus 35 though you may want to stick to kerosene.) As little as 5-8 oz. per tank does the trick. An example of this treatment would be STR-2 sold at many local supply houses.0 -
mobile home furnaces
Oh the dreaded mobile home oil furnace.
I'm from Nova Scotia. I've seen both furnace(#2) and stove(#1)used in mobile home's tanks here. Normally I see stove used though. Your customer might of recieved a tank of summer oil? Was his oil piped in a two line system? Might have a condensation( water build up) in the bottom of top feed tank. I usually try to go with a single line set up on any outside tank and install the oil filter inside.Furnace will work fine, but don't forget to adjust the burner, furnace oil runs a little richer than stove.0 -
outdoor oil tanks
Not a good idea. K1 will offer the best option wiht the most reliablilty. Try to preheat if possible. Cold oil equals poor atomization/efficiency/reliability.0 -
Kerosene instead of #2
We service a number of mobile homes and run them only on #1 as there is much lower sulfur content and it will ignite more readily and not gel if we get a very cold spell. We believe that the heat exchanger life will be a lot longer laso. These heat exchanger are difficult to clean well and the cleaner flame and strainer in the oil pump are other advantages that we believe outweigh the cost differential.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 120 Geothermal
