Radiator Plugs - What's the real name?
Adamal
Member Posts: 2
What do you call the plugs on a radiator that you plumb to?
All of my radiators have a reducing plug (for lack of a better term) and I'm trying to find new ones, but I don't know what to look for.
Most of mine are 3/4" plugs with the center tapped out for 1/2" threads (like a doughnut).
Thanks.
Thanks.
rad plugs
for steam or water?
they are called bushings.
if its steam and the hole is off centre, they are eccentric bushings0
