reverse return on joist heating?
Steve Lamprey
Member Posts: 1
I AM DOING MY FIRST JOB WITH A REVERSE RETURN SYSTEM SUPPLYING WIRSBO PEX TUBING SUSPENDED IN THE JOIST BAY.
WIRSBO HAS NO INFO ON THIS TYPE OF SYSTEM. HAS ANYONE DONE THIS AND ARE THERE ANY PROS AND CONS?
THANKS STEVE
THANKS STEVE
Rev. Ret.
This has info. Caps are for when you YELL.
hope this helps.
al0 -
Reverse return
works well if you loops are within 10% of each other in length. Although, I have many manifolds that are direct return with no issues. Your manifold must be pumped correctly (GPM & pressure drop) to make either piping scheme work.
Warm Regards,
heatboy
climatecadvanced.com
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
