Testing a thermocoupling
Anthony Mobilio_3
Member Posts: 62
What is the best way to test a thermo-coupling to see if it's no good
With a millivot meter
it should be putting out about 25 to 30 millivolts. If you are interested I have a procedure available through our catalog that will give you the procedure.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
