Coaxial Orifice
Bill_3
Member Posts: 34
Tim, The term you used Coaxial Orifice, exactley what does it mean.
Coaxial orifice
is an orifice spud that can be turned closed or opened and set the the flow of gas. Wide open (screwed all the way out) for natural gas and closed ((screwed all the way down) for LP gas. It saves changing oriifces when converting. It is used only on gas ranges as they are the most likely appliance to travel with the consumer.0
- 167 Indoor-Air Quality
