stainless cuts
Dave Palmer
Dave Palmer Member Posts: 186
I have to cut some 6" stainless flue pipe,My question is should I use my nibblers or my chop saw for the best cut as this is pricey stuff. Thanks Dave
  • Steve Ebels
    Steve Ebels Member Posts: 904
    It seems to me
    That Graingers has chop saw blades that are made for Stainless Steel. I know my brother-in-law, who is in the dairy equipment business picked them up there. Don't know the model but they could likely tell you if you give em a call.
  • canuckDale
    canuckDale Member Posts: 77
    Clean cut
    Depending on the grade of the SS, it will likely have to be MIG or TIG welded for best results.
    Ask your welder what he/she prefers and what will be most economical for both of you.
