Cast iron or steel boiler - which is best?
don_9
I personally like a cast iron over a steel boiler.
Cast iron boiler are easier to clean,most have more then one are two passage to flue for better heat transfer,less
stand by losses.And did I mention how manly you feel after sittin it in place.
Steel boiler- most are tube,single vertical passage to flue
less heat transfer,more stand by loss because it hold more water,baffles that need to be replace every three to four years,unless specified most come vertical discharge so can
only installed in area with lots of head room.Can be a pain to clean after brushing all the soot out of the tube will need to pull burner to clean soot out of fire box.
They also don't last as long compared to a cast iron boiler.
Boiler design
Is cast-iron or steel the best material for residential boiler heat exchanger design?0 -
My late Father-in-law,
who forgot more than I'll ever learn always told me that cast iron boiler sections are installed with steel push nipples which meant it didn't matter to him which you used. You'll get responses from some very bright people on this site but I think "Bill" knew what he was talking about.0 -
steel vs cast iron
Heres the first opinion and I, m sure many will agree with me, and just as many will disagree.
1)most all boilers now come with a lifetime warranty.
2)cast retains heat longer than steel
3) steel heats quicker than cast
so I feel , 1)If you have a cold start boiler,steel is more economical, not as much standby loss.
2)if you have a tankless, cast is better.
3) if you're the guy hauling it down to the basement-STEEL is BY FAR BETTER.!!!!!!!!!!
Which is better!
If price matters steel is the one.Selling the house steel is the one,what a unit that will last 40 years cast is the one!I find most steel boilers are done after 20 years but still work on 50 year old cast iron boilers all the time. The different in price is under 500.000 -
Both.
The material the boiler is made of matters much less than the design of said boiler. My most efficient, highest quality boiler, the Vitola, is made primarily of steel. But I have seen many landfill boilers that were made of steel. All sectional boilers are made of cast iron and have varying designs. They range from great to landfill, also.
As far as durability and duration, it matters little what the boiler is made of. If its installed incorrectly, its not going to last very long. Would I put any boiler in a low temperature application with out provisions for boiler protection? Of course not.
There is no right or wrong answer to this, just a right or wrong way to install it.
Warm Regards,
heatboy
"Expert in Silent Warmth"
610.250.9885
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Job Opportunities
