question on dual fuel coal/oil boilers
Dave Yates (PAH)
Member Posts: 2,162
info on dual fuel coal/oil boilers. Any info or links would be appreciated.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=98&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Multi-fuel Boiler
I owned one. Had it in the house for about two years. We affectionately referred to it as the doomsday machine. It was manufactured up in Michigan, I think. The name brand was Conseco. It was hand-fired coal, wood or garbage.And it had a Beckett oil gun hanging off the side of it. The best efficiency rating ever was 60. You had to watch it periodically or it would over heat ,open the relief valve and fill the basement with steam. Not much fun. Good and wish you the best.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
