2-temp systems
Warmfoot
Member Posts: 127
I wanted to see what some of the other guys out there are doing for 2-temperature radiant systems. I.E. in slab & joist heating. Here in the northwest our design temps are high compared to other parts of the country, I find myself doing more in-slab in basements and hanging on upper floors. Occasionally, Depending on floor coverings, my average floor design temps for both floors get pretty close to each other. I like running dual 4-way or VS pumps, and I have even ran a 3-way after the 4-way valve to temper slab water. I just wanted to know what you other guys are doing and if you can offer other ideas.
Ernie Bogue
Master Hydronics LLC
PO Box 779
Keyport, WA 98345
(360) 394-2049
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=178&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Ernie Bogue
PO Box 779
Keyport, WA 98345
(360) 394-2049
2 temp
Check out Wirsbo's new Duomix control made by Tekmar for Wirsbo. I have waited for this thing to come out for a few years now instead of using 2 Tekmar 356 controls, that is if you like injection systems as well as i do.---Al0
- 167 Indoor-Air Quality
