Wood boilers with boiler back up. Piping Dia.-Mike Norgan
Mike Norgan
Member Posts: 24
To all wallies,
Is this the right way to pipe up boilers or do I need a little water to by-pass the heat exchanger for proper flow.
thanks
Mike Norgan
thanks
Mike Norgan
are there..
any plans for a storage tank on the wood boiler to draw off hot water at later times? Thus enabling you to runthe wood boiler full tilt...kpc0
