Using epoxy to connect copper pipe
Greg_2
Member Posts: 3
I came across a residential boiler system the other day that had some kind of epoxy instead of solder for the pipe connections.
Anybody got any input?
Thanks
Thanks
Maybe,some one didn't know how to solder!
I've seen it...
it's called Copper Mate Epoxy. It's approved for use in fire protection systems, which typically have higher requirements than heating systems.
I know the CDA did some research on it's use and found that it was excellent for avoiding flux acid burnout in soft water scenarios.
May be the wave of the future...
ME
Thanks. More info?
Can you tell me I can get more information on this stuff?
Ask...
and ye shall receive. Go to
http://www.noblecompany.com/faq2.html#noblebond
I found this doing a Google search on copper pipe joint epoxy. Lots more if you care to peruse.
ME
Thanks Again !!
- 120 Geothermal
