Gyp-crete pour on our latest job-Mike Norgan
Mike Norgan
Mike Norgan Member Posts: 24
Just poured the gyp-crete on thursday
  • don_9
    don_9 Member Posts: 395
    Nice
    Mike ,Thats a neat job is that a pool room or hot tub?
    If you don't mind me asking how are they controlling the
    moisture problem in that area? don
  • Mike Norgan
    Don,
    That is a pool room. It is a lap pool, and from what they tell me is that there is a soft cover that will be over the pool at all times. They will only have it open when they use it, So it will cut down on the moisture problem. There are four sky lights that will be open when they use the pool.
    Mike Norgan
  • don_9
    Thanks mike
    I am dealing with a pool inside closed room also, just trying to see if there was any options other then that expensive
    Dehumidifier.Had to put one in a small room with a hot tub a couple of months ago,the uncontrolled moisture permeate the whole room. they had to tear out the intire room and had to rebuild.hd boys told her it was ok to installed in the home.10x10 room no ventilation the horror,the horror.
    thanks again mike
  • Nice layout
    of the tubing , Mike .
    Is the Gyp-Crete self levelling ? Looks like it goes in like water . And how strong is the Gyp ? We have never got the chance to work with it yet .
  • Steve Ebels
    Steve Ebels Member Posts: 904
    Hey Mike
    Is there some type of sealer or other vapor barrier under that gyp? Is that Heatway Onix tubing? Inquiring minds in Falmouth want to know.
  • Mike Norgan
    Steve,
    That is Stadler Viega tubing and no they just poured over the sub floor.
    Mike
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Pool dehumidification
    Mike, watch out for moisture and chlorine infiltration. Ignored, much damage can occurr. There will always be very high humidity levels, even with a cover and the chlorine gases can erode every ferrous component within the room. Continuous ventilation with a small pool HRV is highly recommended. I've seen more repairs and damages when owners don't acknowledge the special venting requirements of indoor pools. It's not just enough to heat the space...vent it properly or pass on the disclaimers.
  • Mike Norgan
    Paul,
    The homeowner has taken care of the that, He has pretty much done everything inside, like the pool install and all the wood work inside.
  • Mike Norgan
    Vitodens Project-Mike Norgan
    Here is the latest pictures from the pool project.
  • J.C.A.
    J.C.A. Member Posts: 349
    As Freddie Prince would have said....
    LOOOOOKING GOOOOD ! Nice work on the heating ! Very neat and clean . Being servicable also helps . Great looking job . Chris
  • Dave Springer
    Dave Springer Member Posts: 18
    Mike
    This job belongs in the RPA showcase. I will be saving these pictures to my hard drive!!
    Copy and paste this link for RPA Showcase for 2002 - e-mail RPA for 2003 entry form.
    http://www.radiantpanelassociation.org/public/articles/index.cfm?cat=6
  • Steve Ebels
    Hey Mike SE
    Who did you contract with for the gyp? I just hired Kent underlayment out of Grand Rapids for an addition that's getting radiant. The drive time for them to come up here makes the price kind of nuts.
  • rick in Alaska
    rick in Alaska Member Posts: 1,514
    wall insulation
    Did the homeowner put in the insulation in the wall. In the picture, it looks as if it is pressed into the wall instead of fluffed up, thereby decreasing the r-value. Might want to have it checked out. Also, is the Gyp-Crete done in two pours. In the picture, it looks like the tubing is sticking up a little. In our area, they pour in one 1 1/2 inch shot. Just curious. Thanks, Rick in Alaska
  • harvey
    harvey Member Posts: 153
    just wondering
    i thought that any gypsum product does not react well with water. gyp guys in our area won.t use it on top of a basement floor in a retro application. your thoughts?
  • Mike Norgan
    Harvey,
    The home owner had the tile sealed and with the floor being heated should help out on keeping the floor dry. Also the pool is a lap pool so there shouldn't be much water on the tile.
    Mike
  • tombig
    tombig Member Posts: 291
    Nice Install
    My first look at the venerable 'Vitodens'. Cute lil'guy. Looks like you're heating pool water too. I heard that gyp products don't want plastic to subfloor but portland products do. It's up to the the pour guys. Got to be careful with pool rooms. Chlorine, and humidity are huge factors.
  • Earthfire
    Earthfire Member Posts: 543
    Wondering
    OSB subfloor and Gypkrete under tile next to a body of water .Wet bodies coming out of pool and dripping on the floor. Condensation on the underside of that pool tub and the associated piping under that floor. Things that have been known to cause problems in the past. If sealed tile was impervious to water the code wouldn't require a membrane under and behind tile showers. Luckily sounds like to HO did all the specs. Would be interesting to go back in a couple of years and see how that subfloor is doing .
  • Al_3
    Al_3 Member Posts: 79
    Sealing
    I was always taught to seal the sub with a wood sealer before gyp to keep the wood from sucking the water from the material being applied, isn't this the case in your area?-AL
  • Mike Norgan
    The finished pool - Mike Norgan
    The pool is up and running. This thing is really cool you can hardly even hear it running, I think the water movement is loader then the unit itself. Thanks for all the comments about this project. Now its time to work on posting the next project. Mike Norgan
