Utica steam boiler & zoning with condensate
Bill T
Member Posts: 3
I have a Utica PEG-187 steam boiler and want to install a hot water loop in a new kitchen projet. There are no "good" tappings to use on the Utica Peg series. There is a 2" tap on the bottom opposite the one being used for the condensate return but I'm affraid the return water will just run through the bottom of the boiler without being heated.
Does anyone have a way to do this with the Utica PEG series?
condensate heating
In Dans book HOW COME there is a whole chapter on condensate heating. I think you will find everything you need
good luck joeg0 -
Utica Steam
Bill,
I think we may have discussed this on the phone last week. If not, please feel free to give me a call at 1-800-325-5479 to dicuss.
Peter Desens
TEchnical Service Manager0 -
is there a
tankless available? or a spot for a tankless? i piped a large radiant job through a special 3/4" tankless coil before and it worked great. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Utica Steam Boiler
Bob,
No tankless or tankless tapping on the boiler. I'm stuck using the tappings that are available. Hoping someone had done this before and had good luck with it.
Bill T0
