Conversion Job
Joe Grosso
Member Posts: 307
Installed 19 series 7 section hot water boiler with two 330 fuel oil tanks in a very large christian brothers home.I do not want to do this type of work on every job.These sections are HEAVY.
P.S. Yes we removed a ideal gas boiler and replaced it with this oil beauty :)
Nice looking job,be proud.0 -
You cold have put it in with a gas burner and call it a gas clean buty :-)
Clean looking job. Is that gas hot water tank still being use? I cant see if it is conect to the chemney. Or is it going to be replace by that tankless
coil in the boiller?
The only thing I can comment is that "minimum water line" mark on the boiler is for steam apliquation. For hot water the low water cut off is normaly instal above the boiler.
Francois.0 -
Clean looking job. Is that gas hot water tank still being use? I cant see if it is conect to the chimney. Or is it going to be replace by that tankless
Francois.0 -
Tanks
Is that one feed going into two tanks across the top. The Vent on each end. Do both tanks feed that filter at the same time.0 -
Bill
Yes both tanks are feeding that filter at the outlet of the fuel tanks.Also have a spin on at the burner0 -
Oil lines
Nice job Joe, I like all the valves at the tanks ball valves for service firomatic and osv for safety. What brand tank guage is that?0 -
Oil Gauge
That is roths brand.Real nice little gauge much easier to install than scully or king and takes up hardly any room in the truck.All my tank installs get a osv and a filter at the tank and then a filter at the burner.0
